Carlos Valente
Brazil
FabioV Posted at 5-24 04:24
The matter of fact is that our drones are complex devices and their operations rely on multiple factors: HW/SW of the drones, radio controller, smartphone; environment: interferences, solar activity, magnetic anomalies, and so on and so forth. And also a proper use and control from the pilot. Every time a new firmware is out, a lot of complaints appear in the forum, but when we carefully investigate, in most cases the issues are not related to the firmware, but to some of the other factors.
As an example: I tested my Mini 2 up to a 2.100m distance without a disconnection, but in some specific case at less than 500m it disconnects. Here the issue is clearly related to the interferences that comes from homes on from industrial plants that make the connection unreliable.
My personal policy is: to wait some days after a the FW upgrade announcement, carefully monitoring the forums, and then to upgrade. This is valid not only for drones but also for all the other devices (PCs, smartphones, ...).
FabioV, it turns out that if you didn't update the firmware, dji fly wouldn't let you fly. It was a mandatory update. And I agree that it should have the option to restore the firmware to the previous version, so we could make sure whether or not the problem was the update. |
