KTM80PT
Flight distance : 743235 ft
Go to the https://www.dji.com/uk/flysafe (I’m guessing replace the Uk with US will work)
-Scroll to the bottom and unlock a zone,
-Log in, and make sure your account has your ‘Flight Controller Serial Number’ under device management on the left, make sure all other info filled about you and drone model.
-tap unlock request at the top, select new request, tap on each box and select your drone, serial, email, (this is all pulled in from your account info that must be added prior)
- select you area, and transfer license in the fly app to drone
In my smart controller the ‘Flight serial’ and ‘Aircraft Serial are the same. Make sure you are using the correct serial- open fly app, tap on your profile at the bottom, tap device management to see the serial that is needed. |
