Sean-bumble-bee
Flight distance : 15997 ft
Nienco Posted at 3-27 01:15
(but then again, it's not 100% clear if I will get a message if my phone was not connected to the controller and drone). I took the drone for a flight and everything still seems okay (hope I won't get any surprises in the long run).
Nienco, if you think "but then again, it's not 100% clear if I will get a message if my phone was not connected to the controller and drone). " perhaps you could explain the method of communication between the drone and the phone when the phone is not connected to the controller.
I would suggest an experiment.
Connect everything and switch everything on as if you were going to fly the drone.
When all is ready you see an image, on the phone's screen, of what the drone's camera sees, is that correct?
Touch the phone's screen and, keeping your finger in contact with the screen, move your finger slowly up and down the screen, does the gimbal follow the 'vertical' movement of your finger on the screen? If yes both the image and the movement of the gimbal demonstrate that the phone is communicating with the drone via the controller, do you agree?
Doing nothing else unplug the cable from the phone, what happens? You lose the live image on the phone's screen and what image there is goes to black and white. correct? Is th? Try the moving your finger up and down the screen experiment again, what happens to the gimbal? Nothing?
There is no communication between the drone and the phone. How could the drone let the phone know that the drone is getting hot?
If you like try to start the ''find my drone'' function and press ''START FLASHING AND BEEPING'', if anything happens take note of any messages that pop up.
With the early Fly App (pre 1.2 ) that I use for my Mavic Mini I get a message saying "Aircraft not connected. Unable to start flashing and beeping." With the 1.3 App I use for my mini 2 there is no message, nothing happens.
With the appropriate phone disconnected from the appropriate controller neither of my drones starts beeping or flashing when trying this.
