patiam
Flight distance : 1118740 ft
Slot Tech Posted at 4-4 15:01
Ok, I thought that once the base station is in place, let it sit for a while and thru its antenna it would get its location from all the satellites. Then you would add the antenna height to get the correct location of that spot its set up on. If I had to use a Ntrip connection, I might as well just Ntrip to the Drone and leave the base out of it. But if I have no connection, then the base station can't find itself on earth?
It can find itself, but not with high precision unless it has a source of corrections. The corrections are used to resolve noise in the GNSS signal caused by atmospheric interference, multipath, etc.
You're right that if you let it sit for some time the position will be more accurate, but it is more likely to be in the decimeter rather than cm range without corrections.
Maybe this will help:
https://www.esri.com/news/arcuser/0103/differential1of2.html#:~:text=The%20underlying%20premise%20of%20differential,location%20to%20the%20known%20location.
