tomlesser
tomlesser Posted at 4-8 06:12
Yes, thank you, Ranjan previously suggested starting at about 50%, and mentioned the same, that if the power bank charged the Pocket 2 fully it would "stop charging further even if the battery drained down" and automatically power-off, and then I'd have to retrieve the camera and start it again. The pocket 2 battery is now at 91% (it started at 85%) so I'll see soon what happens when it gets fully recharged.
I set the Pocket 2 up to do Timelapse at Interval = :60, Duration = 5 hours and monitored the battery level. It was attached to an Insignia power bank with a Battery Capacity = 5000mAh and Output Capacity of 2900mAh. I'll admit I don't understand the difference between Battery Capacity & Output Capacity. Photo resolution was set to 16MP and JPG. There ws good news and BAD news.
The charge level of the power bank at start was somewhere between 75-100% ... it has (4) LEDs indicating approximate charge (all were lit), but not a specific % indicator.
At T = 0:00, P2 battery was at 92%, power bank "4 LEDs"
at T = 0:20, 85%, 4 LEDs
at T = 1:00, 72% "
at T = 1:45, 32% "
at T = 2:15, 50%, 3 LEDs
at T = 3:00, 73%, 2 LEDs
at T = 3:30, 78%, "
at T = 4:00, 78%, 1 LED
at T = 4:30, 73%, "
at T = 5:00, 59%, 1 LED blinking, indicating nearly spent
at T = 5:30, 37%, no LED lit
at T = 5:45, 18%, no LED lit
at T = 6:00 the camera had shut down
So, my experiment showed that I can leave the Pocket 2 in an inaccessible location for an extended period in Timelapse mode which will keep if from powering off. I dis-connecetd and re-connected Mimo at each recorded T interval, so that works fine.
BUT, and this is the BAD news, none of the photos were written to the card. I kept an eye on the shutter button when Mimo was connected and watched the little circle go around. It was taking photos, but I don't know where they went. At the end, a 32GB card has some videos and DNG files from the other day, and 29GB of free space, no JPGs. What went wrong?
Thanks for reading to the end. |
