The display you are seeing is the one shown when the screen module is not attached. So your camera is not "seeing" that module. I suggest you separate the modules, clean the contacts (perhaps just rub them with a soft tissue) and try again.
I don’t think that’s the issue. The camera sees my power module because it sees the Batterie and the SD card and I can copy from the internal SD to the one in the power module. I also cleaned it and nothing changed.
connecting to front screen module has the audio setting. (because it has extra 3mics)
battery module does not have the audio setting ,the audio is on the camera unit mic.
Hello there NDUR. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please try to follow the post give above by DJI-ytao on post #6 to see if the issue will persist? Kindly please keep us posted for further assistance. Thank you.
DJI-ytao Posted at 4-5 18:35
Ahhh thx I get it now. Ok so I don’t have audiosettings with only the powermodule.. if I would connect a mic via usb the settings would appear i guess. Thx
DJI Stephen Posted at 4-5 19:03
Did that option was there before the last firmware update ? I sweer I believe I have play with that option while setting my option around in the camera and I believe I activated noise reduction and now my sound is always kind of strangely reduced .
#dji action 2# me too, no audio setting on latest firmware. When i connect to external microphone the sound was soft/slow. Can dji fix this on next firmware update?
It's May 2023 and I've got this same issue (audio menu settings gone) when I use the camera only. When I attach the front display module, the settings show up correctly. Why is this happening DJI?
I used to have access to audio settings until one of the firmware updates. I can't access audio settings now and my recordings do not have appear to have audio.
I have checked my very earliest recordings and it looks like the camera was never recording audio. Please help because it's quite disappointing to have recorded events and find it's missing audio.
