orbitrob
Hi DAFlys and DJI Natalia, Thanks very much for your replies!
DJI Natalia - So from what i understand you're saying that exporting .265 footage from DaVinci is not a lossless process, is that correct?
DAFlys - Yep i am running the paid version (Studio) but sounds like its not a lossless procedure to cut up .265 footage into chunks in Resolve. I've had some recommendations on another forum to try 'Lossless Cut' which gave me good results...though the footage preview window is pretty bad....because it doesn't play well with .265 content. Still its a solution, until i find a better one!
To your comment, "you'd be better with ProRes export"...I'm on a PC, so its not an option unless i grab something from "Voukoder.org" which allows ProRes export on a PC. This might be a dumb question, but can one truly turn .265 D-Log footage from a Mavic2 Pro into ProRes footage even if it wasn't shot that way natively? ....and would someone with a MAC running FCP be able to happily work with and colour grade that "PC-rendered MavicPro2/Pro-Res" footage?
Any thoughts or help greatly appreciated.!
Rob
