Does anyone have problems with vibrations on video in manual mode? A similar situation occurs in other modes, the drone did not fall, attempts to change the video settings do not affect the situation with video shaking. This is fine?
This is normal. The tune on the FPV drone is absolutely atrocious. Very loose and shaky. Even in low winds, the drone shakes hard in a descent in "prop wash" conditions. In rough air and high winds it really shakes hard there too. The built-in image stabilization helps quite a bit, but it has its limits. It can't get rid of all the shaking because it's so bad. You'll always have little wiggles here and there.
Hello there RemyMarto. Good day and thank you for reaching out.
It’s normal. The reasons are as follows:
1. The DJI FPV gimbal and camera
is a single-axis stabilization gimbal; its stability is a bit weaker than the
three-axis stabilization gimbal of aircraft like Mavic 2. Meanwhile, this
design aims to provide a first perspective view.
2. If the control stick is suddenly released when ascending/descending or after moving the
control stick with too much force, it will cause a certain impact on the gimbal
owing to a significant air change surrounding the aircraft or inertia, the
gimbal will shake and lead to the shot video shaking.
3. You can try to fly the aircraft to 20 m and hover it in a windless environment or gently move the
control stick to see if the gimbal or video still shakes. If not, it indicates
that there is no abnormality.
Thank you.
