rivontrd
Indonesia
Hello..
I have a DJI Mavic 2 Zoom and have a problem with my camera shaking every few seconds, so the resulting image is also shaking. I held the camera and felt something vibrate, I thought there was a problem with the motor pitch. I tried to do gimbal calibration but the problem was not solved.
Then I opened the dji assistant 2 simulator to see the gimbal degree for roll, pitch, and yaw. It turned out that my gimbal yaw was at -110 degrees or more (Gimbal Roll and Pitch were Normal). I tried to calibrate again, during the calibration process, I noticed that the gimbal yaw degree was still correct (the gimbal yaw degree showed the actual position) until the calibration progress was at 60% (progress that the position where the yaw is pointing to the right +90 degree and immediately moved at one time to the 0 degree point quickly). In this condition, the degree of gimbal yaw is not read as 0 degree, but it becomes -110 degree (sometimes -94 degree, sometimes -124 degree, sometimes -154 degree, etc). Gimbal auto calibration has been done many times, and the symptoms are still the same (calibration progress 0-60% degree gimbal yaw shows the actual position but after 60% error again), I've also tried downgrading the firmware from v01.00.0770 to 2 versions below ( because I was thinking if there was a software bug), but the problem is still not resolved.
To colleagues who are already proficient in this matter, please help, is there any advice on the problems I'm experiencing?
