DJI Pilot Android 12
2735 5 4-14 12:46
djiuser_3VBYwyALEn4P
Flight distance : 3267536 ft
South Africa
DJI Pilot does not work on Galaxy S6 Lite Android 12, even if downloading Pilot directly from DJI. Anyone else managed to fix this issue.
4-14 12:46
DJI Stephen
Super Moderator
Hello there. I am sorry for the trouble this has caused and thank you for reaching out. Upon checking the mobile devices ( Samsung Galaxy S6 Lite Android 12 ) that you want to use on the DJI Pilot application . I am sorry to say that the mobile device is not recommended for the DJI Pilot application. DJI would suggest using a recommended mobile device for the DJI Pilot application for compatibility and reliability purposes. There is a possibility that the Samsung Galaxy S6 Lite Android 12 will be able to work. But however, since it's not yet optimized with the DJI Pilot application we cannot guaranteed if it will work all the time and if it will be able to run all the functions of the DJI Pilot application while using it. For reference I will post a link where in you can check the recommended mobile devices for the DJI Pilot application ( https://www.dji.com/downloads/djiapp/dji-pilot ). Thank you.
4-14 19:42
DAFlys
Flight distance : 52729095 ft
Might be worth rolling back to Android 11,  Android 12 has not been very compatible with many of the apps.
4-14 23:16
Charl
South Africa
DAFlys Posted at 4-14 23:16
Seems this is the only solution. But going back from 12 to 11 is not an easy operation. Will have to give it a go.
4-15 01:06
DAFlys
Charl Posted at 4-15 01:06
Have a look at YouTube,  there are many guides there as its been such a terrible release.
4-15 01:32
djiuser_iUMugcBVRf8D
Russia
Добрый день когда будет решина проблема с DJI Pilot на андроид 12 . Самсунг м21 не запускается после обновления.
9-28 06:39
