Chaosrider
Flight distance : 1226762 ft
EiraSYS Posted at 5-10 11:41
Send me a copy of that private OP message!
Makes sense the data correction packets handshaking, the goggles may work just like a wifi router
that connects to several clients, one is the drone, the other is one of the controllers (standard one or
DCP=Data Correction Packets
If, as I used to believe, the audience goggles got their signal from the primary goggles, there's no obvious reason why there would be any video quality degradation to the audience goggles, as long as the two were close together. And yet, most people report that their is.
On reflection, the audience goggles getting their signal from the drone produces an economy of transmission channels. The drone is transmitting anyway, so nothing new has to happen in that sense. If the audience goggles got their signal from the primary goggles, that would require an additional transmission path, since there would be no other requirement for the primary goggles to transmit.
But the question remains, what are these data correction packets, and why are they necessary?
That seems to be the root cause for the signal degradation in the audience goggles compared to the primary, the inability to get these DCPs, because the architecture requires handshaking to get the DCPs to the primary goggles, and the audience goggles can't do that.
I'll see if I can come up with a way to describe this more clearly.
Thx,
TCS |
