fans5fad8194
Flight distance : 8320997 ft
hallmark007 Posted at 4-23 10:03
Your flight log doesn’t Show why you lost connection. There can be many reasons for this , blocked line of sight from antennas to drone , out of signal reach, interference etc. but because you were so close it could be an issue with either your hardware or software. With hardware you would need to return. But before you do that I would recommend you delete whatever FW you are on and reinstall it on DJI assistant, for some updating FW on the app can sometimes not complete the update, so its important you update through DJI assistant.
If you don’t have assistant then you will need to go to DJI.com downloads and download it.
Thank you. Updating FW would require me to move up to 1.04, which I have been reluctant to do. "Tis indeed a dilemma. Would I be one of the lucky ones with no issues after the update? I'll have to mull that over. |
