T 20
12Next >
3837 46 2022-4-29
Zoli
Flight distance : 320755 ft
I have T 20 firmware issues. My RC has 02.03.0330 version and my T20 has 02.03.0223 version. I am not able to upgrade or downgrade any of them. Ofcourse there is no DJI support as usually. Drone would not fly because different firmwares.
2022-4-29
Hi Zoli, we are sorry for any inconvenience. Could you please tell us in which channel you contacted our support? Could you please provide us with the reference number such as the ticket number(#111111) to check more details? As for the upgrade issue, may I ask is there any error message? Please provide us with a picture for a further check.
2022-4-29
Zoli
DJI Mindy Posted at 4-29 23:50
Hi. The case number is 4207031. It is like the 02.03.0223 version missing from the server or I even can not connect to the server but I have a stable internet connection.
2022-4-30
Zoli
2022-4-30
DJI Wanda
Thanks for your reply. We are consulting your issue with our engineers. Due to the weekend, there will be a delay. Much appreciate your patience.
2022-5-1
Zoli
DJI Wanda Posted at 5-1 02:32
Hi, Surprisingly, I got solution. I got a file and I could upload it to the RC. I had more problem with this drone than job done. I hope it will change in the future. Thanks
2022-5-1
DJI Natalia
Zoli Posted at 5-1 02:36
Hello, there Zoli. We are glad to hear that. If you have more needs or questions, please feel free to contact us, then we will reply to you as soon as possible. Thank you again for your support.
2022-5-1
basquera
Brazil
I have the exact same problem, could you tell me how you managed to solve this problem?
2022-5-5
Zoli
basquera Posted at 5-5 13:11
Hi. You should write to dji support. They will send a link with a password ( I don't know why they keep it in secret and why the old version is not downloadable). Once you download the old version then copy it to a memory card and put it in to the RC tgen it will refresh. If you won't get answer just write me and I will send you the link. Not sure the password would still work or send you the file.
2022-5-5
basquera
Brazil
Zoli Posted at 5-5 15:45
I sent you a message, dji support is terrible.
2022-5-5
Zoli
basquera Posted at 5-5 16:13
https://pan-sec.djicorp.com/s/AGa3CHxPxsmBMFn
Password: DJI123
2022-5-5
Hi there, we are sorry for any inconvenience. If you encounter any issues while contacting our support, could you please tell us more details? We will do our best to help. And we noticed that our support team has replied to your email and provided the solution. Could you please have a check?
2022-5-5
Victor M
Paraguay
Hola Tengo tambien el mismo problema de actualizacion de firmware en Agras T20. me podrian ayudar. No consideren las versiones del RC con la aeronave. y no puede degradar la version que tiene instalada
2022-5-19
DJI Wanda
Victor M Posted at 5-19 15:01
Hello, there. Sorry for your inconvenience. We will send you PM. Please check.
2022-5-19
fansb8cf8bc1
Flight distance : 15164426 ft
Uruguay
I have the same issue here. T20 drone in older version. Plz share file
2022-5-20
Zoli
fansb8cf8bc1 Posted at 5-20 10:06
The file is too big to upload. Ask dji to send you a link to download.
2022-5-20
Victor M
Paraguay
DJI Wanda Posted at 5-19 23:56
Hola buen dia! Por favor si me pueden enviar el enlace para descargar el archivo ! Para actualizacion.... Aguardo
2022-5-22
DJI Wanda
Victor M Posted at 5-22 06:22
We have received your message. Please tell us your update. Thanks.
2022-5-22
DJI Wanda
Hello, there. Sorry for your inconvenience. We will send you the link to download the file. Please check and try.
2022-5-22
ChristianRam
Flight distance : 1210505 ft
Mexico
Hola, también tengo el mismo problema, el control se encuentra en el firmware con terminación 0330 y la aeronave en la terminación 0223. y no me permite revertirlo
2022-6-2
ChristianRam
Mexico
Pueden enviarme el archivo para descargarlo? les agradecería mucho
2022-6-2
DJI Thor
Flight distance : 13602 ft
ChristianRam Posted at 6-2 06:35
Hello, there. Sorry for your inconvenience. We have sent you a PM. Please have a check. Thank you.
2022-6-3
H4ck3rss502
Guatemala
Good day, please could you send me the link I have the same problem with my T20 drone, the RC and drone do not have the same firmware
2022-7-18
Zoli
H4ck3rss502 Posted at 7-18 10:34
Unfortunately, the link doesn't work. After two months!!!!!! I had to send my drone to dji and they had to reinstall all the firmwares. Finaly my drone works. However, they messed up all the connection to the rc- drone- rtk. Dji is a joke
2022-7-18
We are sorry to know about this. You can contact our support through the link below and our team will help and provide solutions accordingly. http://www.dji.com/support
2022-7-18
Zoli Posted at 7-18 15:07
Hi Zoli, we are sorry for any inconvenience. Could you please provide us with the case number(CAS) to check more details? We will do our best to help.
2022-7-18
Zoli
DJI Mindy Posted at 7-18 18:37
I dont know if you realized but the link you sent there is no agriculture drones at all. Is it a sign? Will dji finish to make agriculture drones. I wish.
2022-7-18
Zoli Posted at 7-18 20:47
We are sorry for any confusion caused. I mean H4ck3rss502 can contact our support team through the link above and our team will help further. If you have any inquiries about your case, please provide us with your case number(CAS) to check details, we will do our best to help.
2022-7-19
H4ck3rss502
Guatemala
So complicated that DJI does its support, it never solves anything, they always send the same steps that one has done, and ultimately their response is to send the drone for repair.
2022-7-19
DJI Natalia
H4ck3rss502 Posted at 7-19 07:14
Hi, there. We are sorry for any inconvenience caused. May we confirm if you meet any problems? We will try our best to see if we can solve the problem remotely and do our best to help.
2022-7-20
Basquera01
Brazil
I have the old update 02.03.223, and it doesn't connect to look for the new update, the support doesn't provide me with the new update to install via SD and simply told me to restart the controller, as if I wasn't done already
2022-11-3
DJI Wanda
Basquera01 Posted at 11-3 05:58
Hello, there. We are sorry for your inconvenience. We will send you the firmware through PM. Please check. About your feedback, we will forward it to our designated teams.
2022-11-4
djiuser_yjbkFBSiaq7J
Flight distance : 644528 ft
Brazil
MESMO PROBLEMA POR AQUI! PODERIAM ME MANDAR O LINK???
2022-11-14
DJI Wanda
djiuser_yjbkFBSiaq7J Posted at 11-14 13:47
Hello, there. Sorry for your inconvenience. We will send the link to you. Please check.
2022-11-14
crodriguez
Dominican Republic
Hi, Same problem here.  can you send me the link for fw 02.03.0223 please
2022-12-22
LEXFLOREA
Moldova
DJI Wanda Posted at 2022-11-14 22:08
Hello, same issue can you sent link for 02.03.0223 remote controller firmware please?
2023-5-1
DJI Susan
LEXFLOREA Posted at 5-1 04:54
Hi there, could you please tell me the detailed issue you encountered with the T20? I will send you a PM (which is available in a computer browser version of DJI Forum) as well, please check it out.
2023-5-2
LEXFLOREA
Moldova
DJI Susan Posted at 5-2 02:52
The issue is that with the new firmare on my T20 smart controller, my missions from agms are not working right on the remote control. No obstacle or route planning data is transfering. I use Terra 2.3.0 as recommended for the T20.
2023-5-3
DJI Susan
LEXFLOREA Posted at 5-3 05:36
Thank you for your clarification. Please try out the updated firmware first, if the issue persists, please reply to our email with the details, a video should be appreciated. Thank you.
2023-5-4
LEXFLOREA
Moldova
Hello, the issue with the maps has been resolved, it was a settings thing.
Now the problem is that when I try to fly it says I don’t have permission to use aircraft. I am logged in my dji account on the remote, and the aircraft is on my agms. Maybe its because the firmware was updated through a different dji account you sent me instead of mine?
2023-5-6
12Next >
