paoman
Brazil
Hi, I bought the Mavic Mini 2 drone (fly more). One of the batteries is not powering on the drone. I did the following tests.
1 - Charged, and the LEDs indicate that it was charged.
2 - I tested it as a smartphone power bank and it can discharge and charge the smartphone.
3 - When adding the drone it does not turn on with this battery. It only connects with the other two battery.
4 - I tried to put the drone on the charger, with the battery, and when I clicked on it worked. But after I turned it off it won't turn on that battery again.
Did this battery come from the factory with a problem? Or is there the procedure?
Att,
