Ronin RSC 2 + RS 2 Tracking Points (Waypoints)?
1202 1 2022-5-7
cvok
Hi folks - !
Is there a way to use the "Track" tool to do a span of points that are a full 360° (and beyond)?
For example, I want the the camera to do a full 360° (ideally 380°) pan over 30 seconds.
Right now, if I put waypoint "1" all the way to the left and waypoint "2" all the way to the right, this accomplishes only about 350°. Point to point that should be 360°! Obviously, I could do this by hand but then the speed wouldn't be constant (I.e., linear). Any ideas?
2022-5-7
AgniesMT
Flight distance : 2644108 ft
South Africa
There is a panorama mode, where you select the size in degrees. You should be able to draw a rectangle that represents 360 view.
2022-12-2
