tohuwa
Luxembourg
Hi all
Got my air 2s last week, and I've been practising and familiarizing myself with the moves and reflexes, all good so far.
Except, when I try to shoot low level flights, say 1 meter over a cornfield or a pasture, the drone nosedives. I'd say that starting at about 1,5 meters, i'ts close to the ground after about 30-40 m.
You can see it from the side, it's a linear downward line. This is independent of texture, surface etc. I tried again and again, thinking I did some wrong or unnoticed moves with the stick, but same thing each time. It also seems that the lower I fly, the worse it is. If I didn't pull it up in time, it would just crash onto the ground.
Is there anything I'm missing or is it a functional issue?
Thanks for any help.
