Front arm leds won't work all the times.
571 3 2022-5-16
djiuser_UTvVnXRYMBQg
Brazil
Hello. Sometimes the front arm leds won't turn on. Other times, it works like normally.
Is this a expected scenario? What does it means?
Also, if I change the led settings, It is instantly fixed.
2022-5-16
DJI Stephen
Hello there. I am sorry for the trouble this has caused and thank you for reaching out. Before having this issue with your DJI FPV, did your DJI FPV had a hard landing or a crash that happened before experiencing this issue? Thank you.
2022-5-16
Brazil
DJI Stephen Posted at 5-16 19:49
Hello. Yes, I did had a high speed crash in the sand, all feet of the drone absorbed the impact. No visibly broken parts:
Edit: Actually, I remember having this problem before the reported crash. As the old picture, attached, shows.
2022-5-17
DJI Stephen
djiuser_UTvVnXRYMBQg Posted at 5-17 04:07
Hi there. Thank you for the reply and for these additional information. Since we are having this issue with your DJI FPV, I would recommended for you to contact our DJI Support Team at https://www.dji.com/support?site=brandsite&from=nav for further assistance with regards to this matter. We will do our best to help you and give out the best resolution for the said issue. Thank you.
2022-5-18
