DowntownRDB
Flight distance : 1722 ft
dcrainmaker Posted at 5-17 10:05
You can swap back and forth between the DJI RC & RC-N1with the Mini 3, in a non-bound configuration. In that configuration, you get 5 times to 'bind' the aircraft before it gets upset. But realistically, on the 5th time, you can switch binding, and then next time you've reset it.
So basically, one controller is considered the 'Bound' controller, and the others are essentially guest controllers. Using it in a non-bound setup requires no connectivity (whereas binding it requires connectivity). I haven't seen any obvious feature shortcomings in non-bound mode. In my case, I've had the DJI RC as the bound controller, but occasionally used the RC-N1 in an unbound configuration.
Thanks, good to know information. |
