Bashy
Flight distance : 2354357 ft
herasymcuk Posted at 5-26 00:09
In this LINK very detailed article from a technical point of view, it is clear that in "most cases", the maximum brightness of the galaxy s22 + will be 829 nits. The values declared by the smartphone parent companies concern only small portions of the screen. "In less adverse conditions and with you in control of brightness, you'd be looking at 494nits with the slider all the way to the right."
Its 1266 nits on max auto when using adaptive brightness.
Quote
Under bright light, with adaptive brightness enabled, we measured 1266nits on our S22 Ultra under the standard 75% APL that we test and compare between phones, which is more than 200nits brighter than the closest competitor, the iPhone 13 Pro Max. It's quite the generational improvement over the S21 Ultra or the Note20 Ultra, both putting out just over 1000nits under the same circumstances.
When you quote something, quote it in full please so folks get the full story, you missed out the important part regarding the Extra Brightness toggle.
Quote
In less adverse conditions and with you in control of brightness, you'd be looking at 494nits with the slider all the way to the right. There's a bit more to that this time around, as there's a brand new 'Extra brightness' toggle in the display settings that appears if you disable the 'Adaptive' toggle. That unlocks an extra 300nits, give or take, manually attainable regardless of ambient light, bringing the number up to 829nits.
Either using the extra brightness toggle or leaving it all in adaptive, its certainly brighter than the DJI RC in bright sunlight.
More disturbing to me is the Note 20 Ultra 5g is only kicking out 1023 nits and not the stated 1500+, still, that's on par with the RC Pro.
If i do get this MM3P, I am sure I will get the DJI RC too for convenience and still have the N1 option if needed |
