Bashy
Flight distance : 2354357 ft
MXss Posted at 6-4 18:42
I will try to do more tests and manual channel selection but its clear to see that alot of users on here and alot of youtubers are experiencing some sort of range issue significant enough to mention in their videos.
I agree, a lot are, but without me seeing a video of the screen so i can see the Flight Attitude radar and a video of the person holding the controller, i can't really say either way, but i do think that this MM3P is very sensitive to alignment, i.e. very directional, more so than previous models. I have seen 2 videos of tests where there's a 2nd video showing the person holding the RC and its not good, its like they are trying to control the space station seen as the antenna on the DJI-RC is pointing into space.
2 things...
1, You need to make sure the compass in the DJI-RC is calibrated, then you need to start using the Flight Attitude Radar, it has an indicator on there that shows the RC's direction in relation to the drone, it also shows the direction your RC is pointing by the little blue arrow on that indicator. once a good horizontal alignment is achieved the blue arrow will turn green, just make sure its 100% pointing to the drone indicator on that radar, tiny adjustments is all that's needed once its green. You can flit back and forth between map and radar but the radar is your friend. Just keep checking that radar cause you will move even if its a tiny amount, at a distance that tiny amount is multiplied tenfold.
2, Try to imagine where the drone is in relation to yourself, at 500m and at say 50m high, its not going to be that many degrees above the horizon, even that distance and 120m its still going to be lower than you tend to think, so when you're holding the DJI-RC at a nice comfortable viewing angle of what, 45º or more? so you can see the screen ok, this ain't gonna work. Once you have number 1 above sorted, you then need to keep an eye on the signal indicator at the top of the screen (like you normally would), So lower the top of the RC so its points lower towards the horizon, but you need to be able to gauge how low, remember this though, the horizon is less than 5km away from your standing position, a little further the higher the drone goes. Make adjustments in tiny increments, then wait a second or 2 whilst watching the signal meter and see what it does, if its goes up then back down, you went too far, if nothing happens, you didn't adjust enough, if it goes up, then try another tiny increment in that same direction, if it drops then tiny back the other way etc, you get the idea.
Once you've sorted 1 and 2 above you will be able to get the best possible out of the drone, and not necessarily range either but the signal itself. The weather is something to consider too, i managed to get my record in foggy conditions, i flew under the fog at 17m rising to 27m at the turnaround spot, i think the signal was bouncing off the fog like riding a wave |
