Stefan Zimmermann
Flight distance : 4719222 ft
In manual mode, you can hardly lose the FPV in the wind. One has more than enough power.
Unfortunately, there are so many vibrations that beautiful video are hardly possible. Also, the video image is very skewed because of the angle of the drone and the wind.
Therefore, I fly only up to a wind speed of 50 km / h.
And even here you have to be driven by wind. Against the wind, the videos are not good.
With RTH, however, the drone flies only 50 km/h. That's something you should definitely keep in mind. Without taking over the return flight manually, the drone may not make it home.
I still use this wind meter to have a better feeling:
http://www.windpowersports.com/wind-gauges/skymaster.php
Cold wind, for example, feels much more violent than it often is in reality. |
