Miguel Leitao
Flight distance : 1977067 ft
Portugal
JerryLaurence Posted at 5-20 09:52
If the bitrate is a max of 150Mbps, will the extra data needed for 10bit recording cause compression artifacts, especially at higher frame rates such as 50p
If i remember correctly 150mbps is the same bitrate as the Air 2S that also shots in 10 bit, so 150mbps should be more than enough. |
