drone for trave
Thanks. The drone had not flown a day since I received it from DJI 2 years ago. So, the props on it are what came direct from DJI with the replacement drone and battery.
I had read where storing the Mini in the FlyMore hard case has a tendency to press down on the props and may distort them. That could very well have happened, but the drone is not always stored in the case.
I thought I had a spare set of props to check that part out, but could not find them and no time to buy a new pair at the moment as will be traveling and wanted to take the Mini with me due to being under 250g.
Submitted a case to DJI, but will probably have to send it back to them for inspection / repair when I get back from travels.
Will order a set of props to have on hand when I do get back and test that out. Had hoped for some other solution in the short term to fly the drone and not get the "props error msg" and even worse - the ESC Beeping on landing. That is loud and I prefer not to have that happening. |
