djiuser_ouNOfUhsepAp
Flight distance : 791480 ft
I voted 'not happy,' but was 50/50 between that or 'on the fence.' I haven't done enough flights yet, my extra batteries haven't yet come (shipping issue), etc (wonder how much can be improved with firmware updates).
I've had the Mini 2 (RC-N1) for a couple years, got the Mini 3 Pro with RC about a month ago... the range is less in the same flight profiles. Bummer. What I haven't yet tested is simply linking the N1 with the Mini 3... I presume the range will be the same, or better, than the Mini 2 (the range is the controller, not the drone, no?).
If so, I may use the N1 for some flights.
Context: Most of my flights, at least during (humpback) whale season in Hawaii is from my boat, following the whales... I can easily go a mile on a flight. More if my boat is drifting the other direction. My Mini 2 did very well, I've been two miles+ away before (open water). I haven't flown the Mini 3 from the boat, yet. But same flights from ground show notably less (controller?) signal range, so I'm worried about the water flights range now.
Also, as the boat drifts... I'm almost never anchored during flight (for good reason: I'll drive to the drone sometimes), or in general...... I need to look into: does the RTH have a return to controller function?
If not, that is needed!
