Chaosrider
Flight distance : 1226762 ft
JB63 Posted at 5-23 09:32
Thank you for the reply. I pondered few scenarios like that but I must run few more experiments. Even though the resolutions are different, the total file size is about the same. I have to look deeper in the settings and explore what options are available. Good point about the exFat/NTFS, though I thought I read in the manual that they use only exFAT. The other variable for me is that the two cards are NOT the same. The drone uses a SanDisk Extreme whereas the goggles use a Samsung PRO. Incidentally when I install the cards initially, the drone complained that the samsung card was not fast enough, so I swapped them, and the goggles (with now Samsung) did not complain at all.... Too many questions, though not sure answers will bring greater wisdom
I use SanDisk Extreme 256 GB cards in both the drone and the goggles. For any given flight, the files are VASTLY different sizes. The card in the goggles still has every flight I've ever made, and it's less than half full. I've already had to offload some files from the card in the drone, because it filled up.
In every case the goggles record the full flight. In the drone, the files are limited to 3.81 GB due to the FAT32 file format limitation. 4K burns that up pretty quick. I'll frequently have three separate, sequential files on the drone card for just one flight. They stitch together seamlessly if you concatenate them with a video editor.
I also noticed the format difference, MOV for the files in the goggles, and MP4 for the files in the drone. That's more than a little weird, and I'd like to know how that came to pass, but it's never been a problem. It's just weird.
Thx,
TCS |
