TheStriff
Flight distance : 24839 ft
I just tested the MasterShots for the Mini 3 Pro.
So you have to select 4K (mine defaulted to 1080P)
But the gotcha is when selecting a template to apply to it, the video gets transcoded (I'm guessing to 1080P, otherwise there's no need to transcode it) then after this it applies the template you have selected, and then export / save is only 1080P while the master video is 4K.
Very disappointed about this, canot find any documentation about this, I'm using a Pixel 6 Pro.
I've been in live chat with a tech person, and don't get full confidence as they weren't sure either, then was suggested maybe my phone is not capable.... Which is certainly is / should be (I use it for 4K GoPro and 5K Insta 360 videos)
So currently I use a Mastershot template. then get the master file into Premiere Pro, and cut and slice it to what the template did, and also bring over the audio form the template.
Export out in 4K....
Would be great if there was also a PC version that we could off load this to.
