djiuser_LTjsCW64VzHT
Flight distance : 225489 ft
fpv_monster Posted at 2022-5-28 01:11
Whata amazing community Literally zero help Since I found the solution myself I thought I would post it in case someone else has a similar issue - you need to make sure that the camera angle is set to a positive number (I am using +20 at the moment) and the drone will behave exactly as expected. If the camera angle is negative and pointing down this is where adding any throttle even when the drone is pointing down, is going to result in increase in altitude
Thanks for the follow up! I have a flown starting with the motion controller then n-mode on RC, then S, and now I’m willing to try manual. Would you mind answering a few questions about setup and such? |
