RH009
Flight distance : 2234616 ft
SgtRay Posted at 5-28 21:37
Good work. Really practice swooping in on them think of yourself as a hawk and if you swoop in and swoop out it'll help you get used to lingering when you get to the bottom of the approach.
Also with a straight run like that start practicing flying completely sidewlying completely sideways. It'll help you avoid the spray from the skier while also being able to get close ups
Thanks for the advice! There is a long sod farm sprinkler that I use as a target, as I swoop back and forth, while trying to keep it in frame. I still have plenty of work to do, in order to be good at it, but I'll keep working on it. Between each run, I would hover for awhile and never really realized how hard it is to just hover in one spot, while in manual mode.... It almost becomes exhausting. A lot of wind over the next week, so I'm not sure when I'll be able to get back out there, but will definitely get out and practice the next chance I get! |
