Manich
Flight distance : 1975351 ft
djiuser_Hxf9ADkMXI2h Posted at 6-26 01:32
I'm in Australia (originally from the UK) and I'm just about to send my Mini 3 in for repair for the same lens fogging issue.
I was just going to the send the drone (minus the propellers and battery) in a separate Auspost (Post office) type box, but then if they replace the drone with a new unit and they send it back in a non original DJI box, I'd be left with a new drone with a serial number which doesn't match the serial number on my original box. That only becomes an issue when I eventually sell the drone, but I'd like to hope it would come back in a new original box with a matching serial number sticker?
Ive not given much thought to the serial number issue as Im looking to keep this for a few years yet, but if I do choose to sell it at some point, it will have to be with both boxes I guess.
As for pairing, its pretty straight forward and theres a button that opens a guide on the home screen of the controller that takes you through it. A few minutes at most.
As for the redesigned gimbal cover, I will upload a pic at some point......but to give you an idea in the mean time, if you look at the thin mouldings inside the cover, the ones that sit around the camera housing, theyve been removed and, believe me, it is so much easier to both remove and fit the cover itself. On a few occasions, due to the resting angle of the camera housing, Ive accidentally caught it at an awkward angle and applied undue pressure on both it and the gimbal itself. With this new cover, that isnt an issue. Just clicks on and off with ease.
As for the fogging issue. I flew my drone for the first time this evening, since it was returned. 1.4k along a beach, over a headland and out to sea. There were cloudy skies and rain falling way out at sea.......and just as luck would have it, as I turned to bring it home, the wind changed and the rain came in. It was about 1.2k away and the wind had turned head on to the drone and it flew around 1k in a moderate rain. It was completely soaked when it landed, with even the lens covered in water droplets and all around the air intakes........but it hadnt fogged internally and even the footage it shot throughout the flight was still usable, just a little hazy cos of the droplets on the lens. I spent a few minutes drying it carefully with a towel and took it out 10 mins later after the rain had stopped with no problems at all.
I havent checked my DJI Care Refresh policy yet, but will let you know. Im assuming its been re assigned to this one through my DJI account.
