fans6317ff2d
Flight distance : 85177 ft
Yazu Posted at 7-22 02:07
That is weird indeed, might suggest trying to reinstall the FW , using the DJ assistant 2, just to make sure it was installed properly. I have the FW same as you FW 01.00.0201
https://www.dji.com/fi/downloads/softwares/dji-assistant-2-consumer-drones-series
I'll do that, will try and test it out over the weekend.
Just to confirm, you are taking 12MP RAW frames and not 48MP?
Also, nice pic, how did you manage to control the glare of the sun so well? Admittedly mine was take about an hour after sunrise (it was a quick stop off at Blackheath on my way back from Tower Bridge) and I was hoping to adjust in post, hence the use of DNG. I have some Freewell ND filters arriving this coming week from the US, which I hope will give me more options, going forward.
By the way, it took me about 10 attempt to post those replies above, my pic was too big and the text was all messed up when I had the pic in the post, so had to separate. It was after a long nightshift, so maybe that was the issue  |
