SeehawerB
Flight distance : 5414203 ft
What's "enough" also highly depends on the contents you film. Flying over a crop field in bright sunshine will need much more data than flying in the dark with most of the image showing no high contrast content.
It's not as easy. If you compare different files you will see that the (mean) data rate is not fixed, it depends on the content and so may vary.
My Mavic 3 shows rates of 120 Mbps in 4K/60 D-LOG, 100 Mbps in 4K/60 non-DLOG, 90 Mbps in 4K/30 non D-LOG in some of my footage. Next criteterium is the coding you set up, H.264 or H.265.
150 Mbps for the M3P is the maximum data rate you have to consider. For the Mavic 3 it is 200 Mbps. You may get these in reality, but most of the time these are not necessary. |
