JJ Wright
Flight distance : 162244 ft
sduck Posted at 6-6 14:35
How are you checking the flight records? Is this your first drone, or did you use the Fly app with a previous drone? Flight records are stored in the app on your phone or whatever device you're using as a controller, not the drone, so even if it was a refurb unit you only get the flights you did since it was installed.
No, used DJI Go 4 app for my other drones, this was the first AIR 2S use with DJI Fly.
Interesting to note though, (I’m not at home or connect to Air right now) in the settings I turned off auto-sync and the records now show a more accurate count - 6 flights. BTW, what is considered a flight? Start-up? Like I mentioned in previous post, when I first opened and connected, etc. I did a couple of indoor hovers, and the next day, did first flight for about a couple miles. Records show a total of 6 flights. Prior to turning off auto-sync, it showed 41 flights. |
