1. Disable Denoise Button
2. Disable HQ Button
3. Full Range gamma RGB fixed instead of limited.
4. A button to Format the card on RC - Found it in Exploring the content of RC (pics ad videos)...damn, was hidden good
5. AT LEAST 720P screen capture. - PARTIALLY SOLVED ON LAST FW!
6. Remember Manual settings if change in video or photo modes (also imported in special modes like Pano and so on).
Some other ideas?
EDIT FROM YOUR IDEAS: 7. Customizable right dial (shutter + - / zoom / Focus closer – further (only if is in Manual Focus)...)
8. Waypoints.
9. PANORAMA PORTRAIT modes.
10. 360 using full capacity of gimbal up.
11. Download photo-video on RC’s SD CARD in full quality (still, there is the option to remove card from drone and put it in RC and you have it, remember that).
12. TRIPOD MODE with customisable max speed
13. Vignetting from Raw fixed
14. Tracking vertical mode
15. Mastershots vertical mode
16. Home Point to be set to RC and updated each 3 to 5 seconds let’s say.
17. Shoot in RAW only18. Streaming (to Youtube or other device). 19. Fix the bug in Bluetooth mode - now is disconecting each time you make a screen recording (would be nice to use the Bluetooth for audio in Screen recording), and after closing screen recorder you cannot turn it on again (keeps going OFF). 20. USE SCROLL WHEEL from Gimbal in conjuction with Button A or B as gradual lowering or increasing Gamma in recording (would get super nice transitions from dark to light scenes). 21. Fix bug related to POI tracking in case of manual unlock with DJI imported certificate.
