Bashy
Flight distance : 2354357 ft
Lok, to be serious just for a moment, the weight added to storage devices requires an electronic charge, each electron is something like 9.10938215 × 10−31 kg. That means the weight is immeasurable to the likes of us, weigh an empty 1tb drive, then fill it to the max and weigh it again and it will weight the same unless you used a lab scales.
Pretty much is said for the battery too, example, a 16kw battery, that's
16×1,000×3,600/1017=0.6×10−9 that's half a microgram for a 16kw battery, so our tiny little batteries make no difference in weight that we can measure outside of a lab, you can work it out using the math above but it will be such a small number it's actually laughable.... |
