Robomaster - Python - Blind - Help Me!!!!!
titanic4wd
Flight distance : 109177 ft
Good morning. My name is Mauro.
I bought Robomaster because I want to teach my son python programming but I have big connection difficulties.
I tried both wifii and usb but both are rejected.
I made a Ping command and the robot responds but if I use the example attached to the SDK:
import robomaster
from robomaster import robot
if __name__ == '__main__':
    ep_robot = robot.Robot ()
    # 指定 连接 方式 为 USB RNDIS 模式
    ep_robot.initialize (conn_type = 'rndis')
    version = ep_robot.get_version ()
    print ("Robot version: {0}". format (version))
    ep_robot.close ()
the robot refuses the connection.
Unfortunately I need to program in this way because my child is blind and cannot use visual programming.
Without this type of programming I don't know what to do with the robomaster.
Can anyone help me ?
I have also tried with the Robomaster software but the speech synthesizers and braille bars are not compatible and cannot read the screen.
I hope I was clear, I don't speak English.
Sorry.
Help me.
A thousand thanks
best regards Mauro.
2022-6-9
Mats Bohlinsson
Flight distance : 1838077 ft
Sweden
Have you tried using the ip instead of rndis?
2022-6-10
titanic4wd
Hello.
I have not done this test.
I tried with a ping command and the robot responds.
In the python program I did not use the IP address because in the description that command indicates the type of connection.
Anyway, I'll try later.
Thank you
Hello.
2022-6-11
titanic4wd
i tried to put the ip address but it doesn't work
2022-6-12
