[size=15.008px]Hello everyone. [size=15.008px]I’m having problems with integrating the Phantom 4 multispectral with corrections using EMLID caster and RS2. I don’t know where the issue is; whether the RS2 side or the drone side. [size=15.008px]Error on the drone app says: [size=15.008px]Weak RTK signal (8012) [size=15.008px]It says its fixed, buy in yellow. This also happens with UgCS, here it says’: Connected. Not in use. ’ and also a message of ‘Weak RTK signal’ [size=15.008px]This happens some times , when I change battery it will either fix well or not, it doesn’t seem to change during the flight so far. [size=15.008px]I tried restarting the drone, controller, ipad or android device connected to the controller. Couldn’t do the base because it is probably 1 km away, but same thing happened it being around 200 m away. [size=15.008px]Didn’t have this trouble with P4R last week, and I’ve been using the same config on the RS2.
[size=15.008px]Any insight on whatever ‘Weak RTK signal’ means would be very welcome. I need info to try to solve the problem.
[size=15.008px]Thanks
