myshko
Flight distance : 313934 ft
Hi all,
Recently received a Mini 3, first drone and in general been enjoying learning and getting footage.
One issue I keep seeming to have is with focus.
The drone never seems to nail it, and often it's just completely out and even if you tap to aquire it just doesn't get sharp.
Here's an example from today:
You can see it try to lock on when I tap the cliff on the screen, but still stays out of focus.
With a small screen (and in sunlight) you can't judge focus easily, so the drone needs to do some of the work.
Pretty much everything from today is soft and out of focus, even stills.
Of course, I can set focus manually and use peaking but surely the autofocus should lock onto basic landscapes???
The '4K' footage is so soft it's bascially HD anyway, so until now I've been unsure if it was the footage is generally soft or if it was out of focus.
With a larger f1.6 aperture, getting things sharp is critical.
Is there some way to reset or recalibrate DJI drones? Is this typical?
Thanks for any help.
