LV_Forestry
Flight distance : 4726654 ft
Latvia
Euc Posted at 6-16 14:39
From UgCS it sort of is. So I assume any camera settings need to be set up in DJI Pilot then It should run:
"DJI P4 Multispectral is not officially supported (the list of supported drones is here - https://www.ugcs.com/supported_drones_autopilots, but we have a few customers with this drone.
With DJI Pilot, you will do nothing. With GSPro you can choose which bands you want to record. Nothing more.
Yes it's true that there are some errors sometimes, especially a constant message telling you that the video return is weak.
Sometimes at startup he is not happy he says that the IMU needs to be calibrated. At first I was calibrating the IMU with GSPro then I stopped. I realized that it is enough to calibrate the compass and restart the application. This happens very rarely.
For me the most important thing is that the RTK is always active and planning on the computer is easier.
My P4M has far exceeded 200 hours of flight with UGCS, no incident to report. |
