Paul3157
DJI Stephen Posted at 6-14 19:59
Hello there Paul3157. I am sorry for the trouble that this has caused and thank you for giving out these information. Kindly please check if you are flying in a restricted flight zone for us to be able to isolate the issue and kindly please check the environment and see if there is enough GPS signal. Please note that if the number of satellites does not reach the minimum requirements, the flight altitude will be restricted. In addition, please check the flight height and distance on the DJI Fly application and adjust it based on your desire settings. Thank you.
Thanks for getting back to me, It seems the problem I had was that I couldn't log in due to having no mobile phone service. Im sure I had GPS signal. So does the mavic air 2 require you to be logged in on your mobile to allow you to not have a flight restriction?? There was many times where I was in the middle of Australia no where near restricted zones at all and it wouldnt go further than 50 meters.
Thanks |
