fansbc846fa8
Flight distance : 196860 ft
Portugal
DJI Stephen Posted at 6-14 19:11
Hello there hans. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please fly your DJI Mini 3 Pro to a different location with less interference to see if the issue will still persist? The DJI drone might have picked up magnetic interference on the ground, and you took off from close to a buildings with rebar concrete metal objects on it. In addition, please make sure that the antennas are pointed toward the aircraft for optimal transmission. Thank you.
[view_image]
Hello Stephen, I've had it at different locations. This is my property, if i stand at the driveway of my office (left bottom of the image, not in view) and fly at 120m altitude to the outer end of it (about 300m, I should check) I lose signal, even the image becomes blochy. As you can see, apart from my office building - which is only groundfloor and a roof - nothing but trees.
