New DJI Air 2S Firmware Released (04/11/2024)
45287 174 2022-6-17
dreamtuner
Flight distance : 2092841 ft
Bangladesh
So is this possibly the last ever Firmware update for the Air 2S?
4-12 01:05
FabioV
Flight distance : 980066 ft
dreamtuner Posted at 4-12 01:05
Maybe some tuning for C1 compliance may be required in the future. But for sure I do not expect any new features (waypoints, for instance).
4-12 01:51
djiuser_6HQgrpVPkCwZ
just updated and try to ask for C1 Cert. - I´m living in Germany. Filling in the country code 049 ?? after all ended up with "System Error - Please try again later" for many times. I think I will give up here and asking for support
4-12 02:19
FabioV
djiuser_6HQgrpVPkCwZ Posted at 4-12 02:19
You country code should be 0049, not 049. I was successful adding a valid address after trying several times, but from the PC, not from the controller. Then I used the controller for finalising the request, using the address added from the PC.
4-12 02:30
at_stephan
Flight distance : 17467 ft
FabioV Posted at 4-12 02:30
I also tested ver often and now with 0049.Everytime "System Error Please try again later
Perhaps DJI could check if there is a problem on their side?
I will retest it at the weekend ...
Regards
4-12 02:54
FabioV
at_stephan Posted at 4-12 02:54
I think it's only matter of server workload ... Many people were experiencing that issue and, after trying few (or many ...) times they solved.
4-12 04:34
MichaelUbuntu64
Flight distance : 1689961 ft
Everyone who has a problem during c1 request with the adress part go to:
https://repair.dji.com/mycase/myaddress
login with your credentials and put the correct adress inside.
Then go back to the fly app and everything will work fine ;)
4-12 09:33
elPaKo
Flight distance : 769245 ft
Poland
After update I got error like on photo. Try to update on DJI Assistant and result was the same.
4-12 09:43
elPaKo
Poland
no one from dji is answering why the drone suddenly stops working after the update... shame on dji
4-12 23:35
FabioV
elPaKo Posted at 4-12 23:35
This is a forum, not a support service. If you are experiencing issues, the best way is to open a service ticket
4-13 04:33
elPaKo
Poland
Hahahaha
Problem is with firmware not hardware. How can you explain why some users have same problem after flashing??? Tell us !
And why can't we roll back to prevoius firmware???
4-13 05:15
Zeb61
Flight distance : 151010 ft
I checked new fw.
All good, but I had no id on flight monitoring app, Drone Scanner and Air Sentinel. Looks strange...
4-13 08:37
at_stephan
MichaelUbuntu64 Posted at 4-12 09:33
Thanks, worked fine. Everything submited within 1 minute. Top!
4-14 02:10
gibecas
Flight distance : 3557047 ft
Zeb61 Posted at 4-13 08:37
I checked new fw.
A me drone scanner lo rileva correttamente
4-14 03:53
gibecas
Ho fatto print screen
4-14 04:19
Zeb61
Riprovato stasera. Nulla. Boh...
4-14 12:56
fansfc4edf12
Flight distance : 42736 ft
Luxembourg
Hi! I am trying to apply for C1 classification for my Air2S and getting a little desperate. I can't change my adress because every time I enter the address it returns a 'system error, try again' message. All updates are done.
What can I do? Thanks!
4-14 13:07
DJI Gamora
Hi, dreamtuner. Thank you for reaching out. We haven't received any notification regarding this. Currently, DJI Air 2S is still being supported. For any updates, please stay tuned to the latest news on our DJI official website at www.dji.com. Thank you for your valued support.
4-14 22:21
gibecas
Zeb61 Posted at 4-14 12:56
Ciao io il test l'ho fatto con drone e controller RC-N1 più cellulare sony android mentre app drone scanner girava su un secondo cellulare android. Il drone era in volo a 3.5 metri di altezza...
4-14 23:06
DJI Gamora
Hi, djiuser_6HQgrpVPkCwZ. Thank you for reaching out and we're sorry for the inconvenience.
1. Please check whether the current phone/RC app system language is consistent with the language of the country where you are located. You need to modify the Phone or RC system language to be consistent with the local language before filling in.
2. Please insert your address here: (https://repair.dji.com/mycase/myaddress). Works best on desktop computers. Afterward, please use the same account on the remote.
Hope this helps. If the issue persists, please let us know.
4-14 23:41
FabioV
Stai usando un iPhone o un telefono Android ? Tieni presente che sui dispositivi Apple la capacità di ricevere alcuni tipi di segnale è limitata da restrizioni di sistema.
4-15 00:25
DJI Gamora
Thank you for sharing this, MichaelUbuntu64. We're glad that you were able to apply for C1 certification successfully. We hope that other users can apply successfully as well through your suggestion.
4-15 00:30
DJI Gamora
elPaKo Posted at 4-12 09:43
[view_image]
Hi, elPaKo. Thank you for reaching out and we're sorry for the inconvenience. Please try to restart the aircraft. If the issue persists, you may consider sending the unit in for a proper diagnosis. You may submit an online repair request through this link: {https://repair.dji.com/repair/index}. If you need assistance with creating a ticket, you may contact DJI support at (https://www.dji.com/support). We understand that this is not the answer that you look forward to, but this would be the best thing to do in this situation. Your kind understanding is appreciated and thank you for your continued support.
4-15 00:50
Zeb61
FabioV Posted at 4-15 00:25
Android. Nessuno dei dispositivi che ho riceve.
4-15 03:11
dji lonix
Flight distance : 136932 ft
fansfc4edf12 Posted at 4-14 13:07
See Post #127.
4-15 04:36
djiuser_LIozbYv0TEjm
Portugal
I can't find the option in my rc to request c1 label.
4-15 05:21
Zeb61
Android by Samsung M30.
4-15 11:00
FabioV
Zeb61 Posted at 4-15 11:00
Ho cercato un po’ in giro: alcuni dispositivi Android pare abbiano problemi di compatibilità con le applicazioni di drone scanning.
4-15 12:35
Zeb61
FabioV Posted at 4-15 12:35
Nel we riprendo i test. Grazie.
4-15 20:34
dji lonix
djiuser_LIozbYv0TEjm Posted at 4-15 05:21
Check if the latest version of the DJI Fly app (v1.13.0) is installed.
4-16 01:01
Zeb61
Does somebody see "shipped" in the C1 labeling progress? I wish I could use Air 2S in my forthcoming holidays...
4-17 03:07
Portugal
dji lonix Posted at 4-16 01:01
I already have the option with the latest rc firmware 01.03.1400
4-17 03:15
lonix
djiuser_LIozbYv0TEjm Posted at 4-17 03:15
DJI Fly App Must be Updates manually, See here:
https://forum.dji.com/forum.php? ... 550&pid=3288210
4-17 04:05
djiuser_8mhVbnL2h6Cx
South Africa
[view_image]
Have you had any response to your query? I have exactly the same errors after installing new firmware?
4-18 11:14
South Africa
My air 2s has stopped working after latest fw update. Same issue as another person on here. Gimbal, barometer etc issues.. see pic. Can we not go back to previous firmware?
4-18 21:34
elPaKo
Poland
djiuser_8mhVbnL2h6Cx Posted at 4-18 11:14
Hello,
My Air2s is at DJI Service Center already.
Think You should do the same...
4-21 11:01
dito888
Flight distance : 2200919 ft
The max. flight altitude which can set, is disregarded with the new firmware.
I set the altitude to 120m, but the Air 2S climb to more than 140m.
Has anybody the same observation ?
4-27 07:56
DJI Gamora
Zeb61 Posted at 4-17 03:07
Hi, Zeb61. Thank you for reaching out. Through the whole application process, you can trace the application progress via the DJI Service Portal.
4-29 00:50
DJI Gamora
Hi, djiuser_8mhVbnL2h6Cx. Please try to restart the aircraft. If the issue persists, please send the unit in for a proper diagnosis. You may submit an online repair request through this link: {https://repair.dji.com/repair/index}. If you need assistance with creating a ticket, you may contact DJI support at (https://www.dji.com/support). Your kind understanding is appreciated and thank you for your continued support.
4-29 00:52
DJI Gamora
dito888 Posted at 4-27 07:56
Hi, dito888. Thank you for reaching out and we're sorry for the inconvenience. Can you please upload the flight record from the app? Once done, please provide us with your DJI Account and the specific flight record that has this issue for us to further check. We'll wait for your reply. Thank you.
4-29 01:14
