DJI Pro Controller Network
559 2 2022-6-18
CreativeSky
Flight distance : 11719738 ft
Is there a way to connect the pro controller to a mobile data network instead of using a wi-fi mobile hotspot? I ask becuase I am curious about this option in the settings for "Network & Internet"
2022-6-18
Tony64
Flight distance : 65574 ft
First part of your question is masked out so I'm guessing you are asking what the Mobile Network refers to, it is if you have a DJI 4g Dongle installed inside the Rc Pro ( Mavic 3 ) not the Mini 3 which enables full Internet Access without having to enable Wi-Fi & then Hotspot on your Mobile Phone.
2022-6-18
CreativeSky
Tony64 Posted at 6-18 14:44
Tony64,
Sorry about the block out. I am guessing that is a forum thing. I went in and put some spaces between the attachment and question but yes, you are correct. I prefer not to have to rely on a hot spot but after doing a little research I see this little dongle is $160 US. Not sure I need it that bad but maybe later as I grow tired if the Hot spot thing.
-Houston
2022-6-18
