KillerKingSSS
Mexico
I havent tried TC but you shouldn't have any issue with the tentacle sync E, it writes the timecode info on the audio track. So you can sync in post. You shouldnt have any problem, except setting the input to the 3.5mm jack in the camera instead of the built in mic. And you will be ready to go.If you use tentacle sync E, you will have to use an external recorder for audio, since it uses the L channel for TC and R for the audio reference from the Tentacle Mic.
