I am using an iPhone SE2 with my mini2. If I access the setup and options menu by tapping on the 3 dots, the menus fill my entire screen. How do I get back to the camera view without closing out the dji app and re- opening?
Hello there. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please try to uninstall an reinstall the DJI Fly application ( https://www.dji.com/dji-fly ) to see if the issue will still persist? In addition, please sync all of your flight records before uninstalling the DJI Fly application on your mobile device for you not to loose your previous flight information. If the issue persist kindly please try using a different recommended mobile device for us to be able to isolate the said issue. Thank you.
DJI Stephen Posted at 6-20 21:36
Thanks for the reply, however I am not able to use a different mobile device. I did make my text as small as possible as mentioned in another reply but it made no difference. Can you add a return or exit button to the menu screen?
I also have the iPhone SE 2020. Because of it's small screen size, the settings menu on the DJI Fly app ends up taking almost the whole screen. On the very left hand side of the screen is a thin line between the settings menu and the edge of the screen. (see photo 1)
I use my left thumb to tap the area and close the settings menu. It only takes me one or two tries to close the menu. Here's a screen recording...
On a 'normal' size screen, that thin area is much larger. (photo 2) Tapping the camera view closes the settings menu. Since the iPhone SE 2020's screen is so much smaller, the menu almost completely cuts the camera view off. But there is just enough to be able to close the settings menu.
dnddad324 Posted at 6-23 10:30
I also have the iPhone SE 2020. Because of it's small screen size, the settings menu on the DJI Fly app ends up taking almost the whole screen. On the very left hand side of the screen is a thin line between the settings menu and the edge of the screen. (see photo 1)[view_image]
fans6734af78 Posted at 6-23 05:21
Hi there. Thank you for the reply and for these information. I will forward these matter to the designated DJI department for attention. Thank you.
