ovidiu.stf
Flight distance : 70948 ft
Romania
You don't need to select the FPV drone from the app, once the goggles are connected to the phone and the goggles, drone and controller are powered on, the app will automatically detect everything.
SOLUTION! I found this on other thread forum.dji.com
It works!
If the app isn't seeing it, then most likely you have the connection set up wrong.
Plug the OTG cable INTO THE GOGGLES, then plug the USB-A to USB-C cable to the OTG cable, and plug the USB-C end of the cable into your phone.
If you reverse the connection (phone -> OTG cable -> USB cable -> goggles), it won't work! It has to be goggles -> OTG cable -> USB cable -> phone.
https://www.youtube.com/watch?v=uRWjV5JvFpY
Thanks! |
