Bashy
Flight distance : 2354357 ft
RalUK Posted at 6-24 23:25
I'm pretty sure the creator of this video bought the Mini 3 with his own money and he was being genuinely optimistic regarding a firmware fix. I agree with you about the DM Productions guy though. Everything regarding his mini 3 is "Fantastic" or "Perfect", I now refuse to give him clicks.
I think it is fairly safe to say that the Mini 3 has signal issues, certainly in CE regions, and I'm not entirely sure this can be remedied with firmware. I can get decent range but the signal starts losing bars from around 300m. It also has trouble with any sort of obstacle penetration. This video shows how poor it is:
This is the very reason why a range test is essential, if the range is good with no issues throughout or till at least near the end then you know that the drone should be ok at close range, as it stands, the range tests in CE proves that this is not the case and your video shows the effects that this has, thanks for sharing chap. As a side note, no way in hell should you have lost signal at such close range and with OS3 no less.
I am wondering if there is a caveat here, as it wasn't obvious in the video, was the controller in the landy? If so, to be honest, this loss of signal even being so close is expected. |
