Sean-bumble-bee
Flight distance : 15997 ft
I am afraid I can't see anywhere in the log that really ties up with your recollection of the flight.
That I can see you may have taken three photos, between 16:49 and 16:56, at this point the drone was 960ft from the home point and the battery was at 16%. (See the PH spreadsheet column BK / 63, entitltled ''CAMERA.isPHOTO''.)
You then flew the drone away from the home point until around 17.58 when the drone was over 1900ft away from the home point and the battery was at 11%. (NOT GOOD)
At around 18:07 (battery at 10% and a height of 37 or so ft) there was a major disconnection lasting 1min 39sec. I do not know what ground clearnace you had at this point but during this disconnection the drone presumably started a failsafe RTH and somehow got to 1533ft from home.
When the connection was restored the battery was at initially reported to be still at 10%, I am pretty certain this is either an error or there is some form of delay in the drone transmitting the battery percentage or a delay, somewhere, in the calculationof the percentage. because 0.4seconds later the battery level reads 2%, which sounds more realistic to me. The drone's reported height is -15.7ft.
It seems you gave it full throttle to regain some height (sensble) but turned the drone at an angle, NOT perpendicular, to what may be a river bank and gave the drone forward stick. In so doing you moved the drone to 1586ft away from home and a few feet from what may have been safety.
The log ends at 20:17 with the drone 22ft below the takeoff point.
I think you made the lethal mistake just after taking those photos, you should have brought the drone home at that point. Instead you flew away from the home point.
I think the ''nail in the coffin'' was the very end of the flight when connection was regained. I am not sure if the 'bank' the drone was heading for (south?) was safe, dry land or just semi submerged plant life but if you had headed perpendicular to that 'bank', rather than at an angle to it, I suspect you could have got the drone over the vegetation/land. However if you had turned the drone perpendicular to the opposite bank (north?) and headed for that north? bank I do think you could have got the drone safe.
All the above said if you look at the log on Phantomhelp or better yet download the csv from there, open it with a spreadsheet program and sort that spreadsheet by column FI / 165,entitled ''App.Warning'' you will find a 19 direct warnings about propeller speed and 54 warnings about possible prop warpage. They are all part of the same thing, it looks as if one or more of your propellors was warped and generating reduced lift.
The props needed checking and probably replacing.
Sorry it's not a favouable analysis and maybe now that I have done it some one will check it and correct any errors, or perhaps you could post the log over on Mavic pilots.
