JJB*
Flight distance : 12225059 ft
Hi,
Had a test flight with my MINI2, but guess it is for all DJI FlyApp drones.
Position not where i normally fly ; so GPS satellites had to be found.
Plus take off spot surrounded by large trees!
Started my flight with low number at satellites, plus the GPS 'health' zero (CSV value, not seen on the FlyApp screen).
My remarks for DJI software engineers;
1) first seen in the screen (top left next to N-mode) : Take of with caution (At...
Remark : At what ??? ofcourse it is ATTI mode ; so do change this into : ATTI mode, CAUTION
2) next on the screen : No GPS. Fly with caution.
Remark : why only short period of time? if i look at my drone at take off i will miss this message on the screen.
3) next a warning : GPS signal weak. Switched to Attitide mode. Aircraft unable to hover. Fly with caution
see the picture.
Remark : this important message on the screen for only very short (a split second) moment !! Why so short ???
(slow down the video to see the message....at 4.8 sec)
4) with the GPS icon red and Vision used drone is flying 'normal', stability is oke.
Remark : why do i see "N mode In Flight" ?? do change that into " ATTI vision " so remote pilots are aware that drone is not flying in a GPS stabilized mode!
5) when flying in ATTI mode, with or without vision, i do not want to see "N mode In flight" ; why not show the actual flight mode thus ATTI or ATTI vision....
Seeing the "incorrect N in Flight" mode gives me a false feeling of flying 'normal'! (for sure if you missed the messages/warnings looking at your drone and not the screen)
Just for info
When the GPS icon turns from red into amber than drone is flying in a GPS stabilized mode. (so the height limit of 5 meter is reset to user max height setting)
Distance shows - - m ; this is seen when the number of GPS sats are low and/or GPS health is low. The moment the GPS icon top right changes into white HP is set and distance starts to indicate and ofcourse the H icon is seen in the radar/attitude indicator.
cheers
JJB
