Bussty
Flight distance : 320951 ft
New Zealand
Blériot53 Posted at 6-27 12:42
Same here! Just this minute brought it in from an evening flight. Still getting to grips with the RC for setting master shots and so forth. I definitely need more practice. The gimbal still vibrates on start-up sometimes, but a gentle tap stops it. Not sure if it's a problem I should be concerned about. Everything else seems fine - and I can reach VLOS limit in all directions, which is good enough for me.
Maybe take a video of the gimbal shake and post here? I'm sure there is enough experience here to figure out if it's a return case or not might be better addressing now rather than later? My gimbal makes a little noise when it starts up but less than half a second but I must have a close look and see if it's vibrating. Very happy with lens clarity, some of the earlier units were a little concerning from what was posted here.
The upward swing of the gimbal is a massive feature on this drone and makes it unique in the current prosumer line up for DJI I think I will be using it a lot as tend to take a lot of shots including clouds :-)
Haven't tried range yet but managed to easily fly the drone above my house when being well inside the house and completely blocked from the drone, was quite amazed actually, there must be a lot of radio waves bouncing and reflecting off walls etc? |
