fans02cb46b4
Flight distance : 298399 ft
MySky Posted at 2022-6-27 10:59
Honestly i have always deaktivated the subtext, but if i take this example: [rel_alt: 17.000 abs_alt: 116608856.000]
rel_alt: relative hight in relation to the homepoint
abs_alt: total hight calculation by airpressure in relation above sea level.
Sounds like your attempting to describe Pressure Altitude? Pressure Alt is the altitude at sea level in standard atmospheric conditions which is a pressure of 14.7 psi also calculated in inches of mercury at 29.9" at standard temperatures of 15* C/ 59*F. This is a theoretical datum plane to which atmospheric conditions are relative to. The drone would need either a mechanical or digital altimeter which is calibrated to calculate pressure of the air around the drone relative to the standard pressure of 29.9 at sea level to know what pressure altitude it is at. Atmospheric pressure changes constantly regardless if a change in altitude. also the higher up in altitude an aircraft is the LOWER the atmospheric pressure around it. the altimeter that is calibrated at sea level of 29.9" calculates the difference of these two pressures and converts it to feet. For every 1000' altitude gain the pressure drops 1" of mercury.
I do not think ABS ALT stands for Pressure Altitude. I have a flight where my ABS ALT is 763' but my drone is returning to home at default 164' REL ALT. My location/Home point is at 1800" MSL which stands for mean sea level, the altitude above sea level.
It certainly isn't Absolute Altitude either since the drone does not have a radar altimeter and would have to use GPS data to calculate this which it possibly could do. Absolute altitude is the altitude above the ground AKA AGL (above ground level)
I'm curious to know what Alt my drone was flying at and what the ABS ALT of 763' stands for. its not pressure altitude, not true altitude, not absolute/AGL, which only leave indicated altitude but this reading cant be it either because my "ABS ALT of 763' on a 88*F day although temperature is irrelevant for this topic, (I do not know the QNH/barometric pressure at that time but I would estimate my drone to be flying at about 1978' MSL. about 178' AGL. I launch from my deck which is 15' above the ground.
lol. That covers 90% of the altitudes in aviation. I'm a pilot. |
